Can anyone please help with the wet face / flush mounting of a 2kW 200-8B and a CA50BL-12R furuno transducer in a fibreglass 23 foot hull. I believe I have the correct location sorted.
As I believe these trannys are rubber coated and bolt down what do I use to seal the trannies to the fibreglass to achieve a perfectly smooth surface and not create bubbles.
I would also install a wet box internally over the trannys to ensure it is watertight but for ease of construction can we use aluminium for the wet box without affecting transducer performance. The plan is to silicon the wetbox to the hull and clamp it down.
And are gland nuts for the tranny cables readily available.
Regards
Kim gageroads23
Regards
Kim gageroads23
