Hello,
Present heaving the FCV295 paired with SS270W. Recently starting to fish in 300-500 meters range and the transducer performance is not satisfactory, of course. Think to achieve a LF transducer and keep the existing one for HF only. But the mounting options are limited, so the only viable option seems to be in hull mounting, into a wet box (also not much space around). To compensate the signal loos through fiberglass will install a 2kW unit. My first question: is it possible to set up the FCV295 to work with SS270W on HF (200kHz) with 1kW power, and with the 2nd transducer on LF with 2kW power? And the second one is which transducer you recommend (mainly frequency and cone angle) for best result in salt water till 500 meters depth? Targeting mainly cod.
Thanks!
Thanks!
