Chart updates
Cabo92
Hello all want to chart update my 3 tzt3's.
Is C map wide still the best option? I believe cmor is also on the units. I fish the gulf
Coast thanks
I would recommend looking over all the MM3 available charts of your area using our Chart download filter at our website. It depends on what your looking for. For wide Navigation needs along with good bathy line charts (fishing charts), I would recommend C-map. For select bathy photo of relief bathy CMOR is very nice but a bit limited coverage area and costs a bit more. Some people buy both. If you have an existing license to MM3 c-map you can get a upgrade price from you dealer (normally half price) normal cost. CMOR charts are purchased directly from CMOR and not aware of any discounts on upgrade.
2 of my tzt3 are from 2022 will they still have the the MM3 C-Map loaded onto them ready to unlock after I buy the code? Specifically looking for MMA-VNA-023 to unlock
Yes, even current unlock codes are backwards compatible and will unlock the older loaded map for which the code is designed. It would be recommended to consider upgrading the map to the most current licensed when time is available. MM3-VNA-023 would have been preloaded at that time so unless someone removed it, current purchased unlock code should unlock it. Ensure after unlocking to change the chart type to "C-map" so it can be viewable.
"available charts of your area using our Chart download filter at our website"
Website seems to have changed. I cannot find this option.
The Furuno USA website link for charts is: https://www.furunousa.com/en/produc...ay/browse?filter=Discontinued.eq.false&group={CFBDF652-0102-4A61-9835-CF99FD2D0A6F}&groupName=Charts%20for%20NavNet%203D,%20TZtouch/TZtouch2/TZtouch3/TZtouchXL
This can also be accessed by going to https://www.furunousa.com and selecting Discover Products-Multi Function Displays-Charts for NavNet 3D, TZtouch/TZtouch2/TZtouch3/TZtouchXL Once there, use Chart Type filter on the left side of the screen.
The first link doesn't work: "500 Internal Server Error"
The second link: I see no "Chart Type Filter" on the left side of screen (for TZT39F).
I have a TZT39F... can't find where to download chart updates (I assume those needing purchase such as CMAP will then require key ourchass from deaker. But where to download?)
