No, it isn't okay. It needs to be shielded with metal connectors so the shield connection is passed and the data lines are protected. Doing otherwise may work sometimes but it is a problem waiting to happen. You can run your car with water in the radiator instead of antifreeze and it will work most of the time, but there is normally a day that comes along that will make you regret it.
