My system comprises of a fanless pc running tzv4pro connected to a dlink 5 port 10/100/100 switch which has a Dff1 an fa30 ais and a psu 12 connected to a drs4 radar
An Actisense ngx1 usb connects upto a point 1 gps puck with built in heading sensor
Now when I installed it all everything seemed to work all ok then I acquired a TZT 14 and is connected to the switch and also an NMEA 2000 connection to bus (the radar has its own nmea2kcan bus connection to another gps puck with built in heading sensor separate from the other bus as per furunos connection guides as it bridges the can bus with the net cable Ok problems have arisen now whereby the sounder just switches off for no reason when everything is on and a disconnection alarm sounds on the tzt14 then sometimes the tzt14 goes blank screen and then shuts down
Now I’m using standard rj45 fly leads to all the instruments wired by the cat5 wiring to plugs and all worked okay till I added tzt14 wiring plugs as follows
1 wh/or
2 orange
3 wh/grn
4 blue
5 wh/ bl
6 grn
7 wh/brn
8 brn
Prices for furuno cables seem extortionate especially since I’m a systems engineer and have an abundance of cable and plugs so I can make up my own cables
The big question is
Are furunos cables wired differently I’ve been digging thru diagrams and noticed some weird pin outs etc
Please can anyone help give me info on which wiring it should be
1 wh/or
2 orange
3 wh/grn
4 blue
5 wh/ bl
6 grn
7 wh/brn
8 brn
The big question is
