discoveryplus
Hello,
There was a bit of confusion on which transducer to get for TzTouch2 / DFF1 UHD and we ended up with Airmar B175L and B175H which I believe are not supported by my setup for CHIRP.
Here is what Airmar wrote:
One last question is the B 175L and B175H usable for chirp technology? The directions say if you have to use manual mode as not listed ( no TDID), then I can’t use the Chirp technology? Please confirm. Thanks so much! Bill PER FURUNO SET UP: The Manual mode for the sounder setup is only used for non-CHIRP Transducers. This mode will allow a specific frequency for both the High and Low frequencies to be selected. FROM AIRMAR TECH SERVICE A DFF1-UHD is required for two transducers to be installed. Attached is a document that will walk you through some of the setup but it has a bit of age attached. Also, you will need to substitute the B175 pair as it is not listed in this write. For more current information it will be best to direct this enquiry to Furuno directly.
My question is, which transducer should we get instead. Furuno website says B275LHW for thru hull here: https://furunousa.com/en/products/dff1-uhd. We have a 30 foot Grady White Express.
Thanks.
Thanks.
