I'd like to know how much a high speed fairing can be trimmed. This kinda relates to my other two transducer posts but is specific to the combo transducer or B260 housing in a high speed fairing. See the picture below and can I cut it to 3.5" total height?
I did cut down a B260 that was mounted on my prior boat, but I don't think I took it down to 3.5 inches. Probably more like 4 inches. Was originally thinking of cutting down a 165T-B54 fairing which at 3.5" leaves a lot more meat, but why not see if the ultimate transducer will work before going to plan B. This install will also require me to put in a 2" to 1" spacer since the existing thru hull hole is 2". But if the combo TD with a trimmed fairing will work and be structurally sound it's probably the best option.
