Keta
I have a tzt3 driving a thru-hull B275LHW transducer in a glass boat, 28' Farallon Walkaround. Works great at troll speed et cetera. IE I like it when all the gear is in the water and I'm fishing.
As I increase speed when in CHIRP mode it's like a bunch of gain is introduced into the picture. I can still track bottom even out to 100 fathom with no gapping but the unit is unuseable for finding fish at speed. Furuno USA came out to the boat, Eric was one of the guys and felt something was off with the install....great service. It works better dumping a bunch of gain, gain that I can use trolling/fishing and switching from CHIRP to CW but that's a pain in the ass and doesn't me much spotting fish or bait when on plane. Life took over for a bit so I neglected the troubleshooting path till now. Fishing season is getting close.
Yesterday I crawled under the boat to take a good look at the install. There is a "Slight" lip with the the transducer not being 100% flush with the fairing block. Fairing block extends slightly further down. You can also see some gapping between the transducer and the fairing block. Trailing edge has a bigger gap but the front has some gap also. Would this be enough to be causing my problems? Would it be worth trying to fill the gaps with some silicone sealant to try to smooth the waterflow?
Thanks,
Kim
Thanks,
Kim
