SS164-20 paired with TZT3 (12inch) - LEARN MORE
MTBTGT
Hi,
Looking to learn more about the ss164-20 compatibility with tzt3. We have purchased a new boat and are struggling to work out ideal gain, clutter and other settings to mark bait fish and marlin when trolling between 6-10 knots. Water depth would be anywhere from 200 metres ( 100 fathoms ) - 400 metres (200 fathoms). We are only looking to scan roughly the first 125 meters (68 fathoms) of the water column.
It seems the transducer is placed correctly, the tilt is accurate for the boats deadrise and the initial set up between transducer wiring and Tztouch was done by Furuno in WA (Aus).
We have looked at selecting the right transducer in transducer settings, playing with gain, clutter, TVG, colour erase, picture advance and everything else etc. I know asking for the ideal settings would depend a lot on the boat, where the transducer is mounted and going over bait at the same time. However it is becoming very frustrating LOL. So I thought why not ask a great community for advice. A few settings from the guru's in the field which might be able to help us out, or just some tips, or further knowledge, here to learn as much as I can. Any information will be a massive help Thank you all so much.
Talk soon
High Frequency
Gain: 70,
Colour erase: 26
HF clutter: 2
HF TVG: 3
Picture Advance: 1/1
(60 metres, 6-8 knots)
(Only Difference)
Gain: 87 (Note: still says 70 on the screen, not sure why)
Clutter: 6
TVG: 1
MTBTGT,
Could you please provide a picture of the TZT3 showing both the Low and High Frequency on the Fish finder using the dual frequency screen. And are there any other Fish finders or Sonars that are onboard and may be transmitting while you are using this TZT3..? :unsure:
- Deep Blue
No other fish finders or sonars, the only other device would be the radar, but it would’ve been turned off during these photos.
Gain 83
Clutter 0
HF
Same settings and depth.
LF:
I couldn't find any screenshots with dual frequency, however the above screenshots were literally seconds apart.
I am fishing tomorrow, is there anything that you would like in addition for me to get photos of.
I have read your " boost the gain, in three times the depth of water until there is a second return/bottom." I have tried this but I am going to try again tomorrow nonetheless.
MTBTGT,
If you can provide pictures of the fish finder using both the dual frequency in shallow and deep water, that could be helpful. :unsure:
- Deep Blue
Still an ongoing issue, but due to having our first baby, there’s been little to no fishing. I did get out yesterday and get the following images.
A reminder:
- Tz touch navnet 3
- SS164-20 through hull
Photos are: auto fishing with 0 HF gain, 0 LF Gain in 6-7 metres of water at different speeds 4 knots 7 knots 17 knots, 25 knots (speed can be determined by top left of Yamaha screen)
Ultimately we noticed that between 5-9 knots the sounder will not read the bottom
Obviously the quality of return picture is awful, but is there something else that we are missing. Just wanting a clean image and to diagnose whether we have an electrical issue or should look at changing transducers?
More photos, speed in the top left corner of Yamaha display
MTBTGT,
The TZT3 appears to be experiencing internally generated noise, likely stemming from either mechanical or electrical sources within the boat. Mechanical interference may originate from components such as motors, bearings, pumps, or shafts. Electrical noise, on the other hand, could be caused by generators, electric motors, or unstable power supplies.
To help mitigate this issue, try navigating to the TZT3’s settings via:[HOME] → [SETTINGS] → [FISH FINDER] → [INTERFERENCE REJECTION] Review the current setting and experiment with different options—Off, Low, Medium, High, or Auto—to determine if any adjustment reduces the noise.
Additionally, please verify that an Earth Ground wire is properly connected to the Grounding Stud on the TZT3. This connection is essential for minimizing and combating any electrical interference.
- Deep Blue 🦈
