p66
What is the maximum speed that the p66 transducer with a 620 FURUNO probe can measure the depth?
My transducer is parallel to the bottom of the boat, what angle I'll have to use it to mark the depth at speeds exceeding 7 knots? I'll have to make a play for the transducer get this new angle?
Hi Metroncanon,
there is a setup that works for all, the right position of the transducer as well as his inclination may be different each time.
You just have to patiently try to change the angle until you get the best result.
Narvalo
