Navpilot 300 on inboard, rudder feeback required?
ToddF
Have a single straight shaft inboard with rudder. For Navpilot 300 do I need to install a rudder feedback unit?
Don't really care about position of rudder on display, just want to make sure all other functions will be ok.
Yes, technically an RRU is required for an inboard installation. If the boat is small, nothing keeps you from lying to the system and tell it is an outboard and giving it a try, to see if you like it without. The pilot will always work better with an RRU and at speeds lower than 3 knots, because the system really needs that RRU to know where the rudder is. Unlike outboard RRU units that get broken a lot, the inboards are rock solid and add a lot to the pilot performance. If it were my inboard boat, I would get the right inboard package with the RRU.
