hub 101 nmea to wifi adaptor
gaffrog24
im trying to get my fa50 to transmit via wifi to my ipad. i have purchased digital yacht WLN10 Smart adaptor that i hope to hook up to the hub101. can you give any ideas on how i can set this up
Output of the FA50 is in NMEA 0183 standard RS422 format. It would be best to speak with digital yacht on how to connect their product. Maybe someone on the forum has the same device and can comment.
Can you tell me which wires do what when plugged into the hub. I need to know the NMEA 0183 in and out. I plan to attach a cable to the hub then splice it into the wireless server. Is there a diagram of which wire does what? Thanks for your help
Don't confuse Network (Ethernet) with NMEA 0183 because they are not the same thing. The NMEA 0183 is on the power data cable and the Network is the RJ45 port. The pin out for the power data cable showing the NMEA 0183 colors is on page S-1 at the back of the manual. You do NOT want to wire your network RJ45 to NMEA.
