Teffy,
Since moving the antenna connection on the back of the unit seems to help from time to time; I would have to guess the connector on the cable most likely has a problem. This could be from corrosion or broken wires that make contact poorly or intermittantly. I would recommend removing the antenna cable from the unit and opening up the connector and giving it a good inspection. You might need to cut the cable back and re-build the connector. Many times you can re-use the connector but if it is too far gone, you can always buy a new connector to put on from your local authorized Furuno dealer. By the sound of it, the odd are, that will reslove the issue. If not then there are other troubleshooting steps you can take.
Johnny
