Furuno vx 2 149
Jordy5130
Hi guys wanting to check if any of these are the lcd model? And which is newer?
-3564 is from Jan 2006 and the other is from April 2009, both are the CCFL type.
Because we will not continue to look up random units, you might make note that the newer LED backlit units are serial 4323-5001 and above.
Disregard if the first 4 are not 4323.
No, NN3D started the digital radar "DRS" evolution. Analog radars can not go further into the newer NavNet Series units.
Would looking at the amp draw also tell if it’s a led back light? The 7.4 amp is led and ccfl is 9.3 amp?
Also Im regards to sounder , is there a transducer that plugs in direct or do I need to get a DFF1 ??
And one last questions do I need a external antenna for GPS
Yes, @Johnny Electron was saying that you need an external GPS antenna (or NMEA input) such as a GP330B/0183 in order to get position on your RDP149.
Yes, you would need a DFF1 (no longer sold) or the current BBDS1 network fish finder to plug your 50/200 transducer into.
Ensure you have the latest software for your LED backlit RDP149. Here is a link to the software and instructions:
Software- https://furunousa.com/-/media/sites...2_10.4_inch_led_backlit_software_ver_4.03.zip
Instructions- https://furunousa.com/-/media/sites...re/navnet_vx2_software_update_procedure_3.pdf
