Quitsa
My TZT 3 16 displays have developed an odd condition. It only happens after they have been running for at least an hour. When in full screen mode, if you try to switch the left sidebar from "Data" to "Route"or vice versa, the screen will freeze. It does it regardless of whether it is on plotter, sounder, or radar. Oddly isn't completely frozen because it is possible to tap the Home button and switch screens. If you switch to another full screen, it will freeze again. With a two or three panel, it doesn't freeze.
Shutting down and restarting fixes the problem until the unit has been running for a while.
Is this a known issue? I did a factory "hard" reset on one unit as an experiment and the problem came back. This just started a few weeks ago with nothing having changed on the system.
