First off have never updated unit since new.. was running 1.07 perfectly.. figured if it aint broke dont fix it.. well got the new bbwx4 Sirius module to run Xm weather and fish mapping.. need to update for communication purposes..
here we go -- i'm using a mac-- started update to 2.05-- update started but never received "remove usb" i see this is typical for mac.. update appeared to loop and re install for next 2-3 hours.. finally booted up and touch screen would not work at all.. non responsive. also got a hardware fan speed alarm...
had to use roto dial and buttons to navigate.. attempted to shutdown and unit- went through shutdown process and landed on the Navnet tzt3 screen.. would not completely shutdown..if left for 3-5 mins it would reboot.
Found Software 3.01 downloaded with Windows computer-- insert usb stick - turn on machine- starts to install.. everything back up and running so it seems.. touch screen working again as normal. BUT
THE 1st PROBLEM-- Connect to Wireless LAN will not activate.. cannot connect to internet. the wireless toggle will not go from "off" to "on".
THE 2nd PROBLEM-- when shutting down unit will still go through shutdown process and once again land on the NAVNET TZT3 screen-- if left for 3-5 mins it will reboot.
Long story short-- My unit was working flawlessly with original 1.07 software-- I updated to 3.01 and I have no wireless internet connection and Shutdown is not shutting down. PLEASE HELP!!! I have been on the phone with tech support numerous times and no answers. :questions :questions :huh
