This is a typo. It should read "Note: [FishHunterDrive] is not shown UNLESS [Boat Type] is set to [Outboard] or [EVCS-Outboard]."
You do not even need the gateway attached to see the option to turn on FishHunter Drive. You only need to proper software versions installed. However, it will produce errors the instant you turn the feature on.@FishTech I know you have been involved on several of these boats. Can you comment on above. While obviously not going to get anyplace until the gateway is configured, shouldn't he still see the settings on an updated pilot?
A single "Suzuki 4 Tank Gateway" will support multiple engines.Additionally, do you need one gateway per engine or is it one gateway for both engines in a dual engine setup?
Did you have any issues installing the RRU on your DF350? I assume you have a tournament series steering cylinder. Seastar is telling me that the smart stick will not fit on this setup.Hi all, just a quick run down of my setup. I have TZT3 16”, navpilot300, SCX20 and a 2021 plated Suzuki DF350A with the L00 BCM and the SMG4 gauge.
I had received the updates from Furuno dealer and update the software through autopilot.
I have added to the setup the Suzuki gateway 96L12, a Suzuki multi gauge adapter cable. The adapter cable allows the gateway into the system whilst still having the functionality of the SMG4 gauge. No need to buy a separate Suzuki mfd which is what I was told I need from the Suzuki dealership.
With the old L00 BCM there was an error code. I brought the new L02 BCM and had the Suzuki dealer reprogrammed the system and now the fishhunter drive is working.
As mentioned above the SMG4 needs the primary mode switched off to allow the gateway to function correctly.
The point lock function is currently locked out in my system as it requires RRU to working. When ever the fantom rudder is selected in the setting manual the point lock function will be locked out. I will be including the AR4502 telestick very shortly.
How many motors do you have?Hi all, just a quick run down of my setup. I have TZT3 16”, navpilot300, SCX20 and a 2021 plated Suzuki DF350A with the L00 BCM and the SMG4 gauge.
I will not have the Suzuki steering system. Honestly I'm not sure what you're even referring to, unless you mean the new 2023s with the rack and pinion steering. Mine are 2023, but not that version.If the Suzuki steering system is used they provide the needed feedback without need to install an OB RRU. The video we shot was on such a boat. No RRU was needed for point lock due to them providing rudder information. Without RRU most Fish Hunter features work with fantum feedback just not point lock.
Hey mate, I only have the one outboard and no I don’t recall the gauge having that information on it nowHow many motors do you have?
Do you still have the fuel burn and fuel trip gallons working on the smg4?
Hey mate, no sorry I have got around to into a RRU as yet. You’re on the money it is a tournament series. I was where at it won’t work.Did you have any issues installing the RRU on your DF350? I assume you have a tournament series steering cylinder. Seastar is telling me that the smart stick will not fit on this setup.
Do you mind sharing some pictures and/or the install sheet? I don't have the motors hung yet but I'd like to see how you set this thing up.Hey mate, no sorry I have got around to into a RRU as yet. You’re on the money it is a tournament series. I was where at it won’t work.
I do have an install sheet which shows how to adjust the RRU end sensors
Hi mate, sorry have been off line. I still haven’t got to installing the RRU as yet. Do you still need the set up sheet?Reaching back out, my motors are being hung as we speak. Any luck getting the RRU fit up properly to those tournament series cylinders?
Hi mate, can I ask what type of RRU did you install? I am looking to finally install a RRUwe made custom bracket for our rru to fit the steering cylinder. it works perfect
