Fish finder screen intermittent scrolling on 13XL?
sheakx
Boat was launched on April 3rd and have made several half day fishing trips with no fish finder problems with the internal sounder on the 13XL. Also get excellent fish detection with B175HW/12 transducer. In the last couple of days, the fish finder screen scrolling starts and stops intermittently. Water temp is about 50 degrees F. Checked transducer cable and connections and these look good. Any thoughts on what may be causing this? Transducer is just over a year old and has been working perfectly since install.
Thanks ...
have you tried to reset echo sounder to default settings ? its on the echo sounder menu. see if that helps you out with your issue.
How many XL displays do you have? If you have more than one, ensure that the fish finder source is set to the correct display. Also, did you try both resets at the bottom of the fish finder menu (hardware and settings to default)?
The bare wire in the power cable and the ground lug on the display...are they both connected to your bonding system (i.e. Dynaplate) or to the negative DC if you don't have a bonding system? If not, please connect them and try it.
