Strider493
I've got my 295 up and running and have some questions on my next step.
This summer, I would like to get a transducer to use while deep dropping for swordfish. Depths would range from 1200' to 2000'. I don't need it to be able to read bottom while going very fast. My plan is to use it while moving at no faster than 8 knots. I don't need it to mark swordfish (although that would be great) but instead to find the thicker/denser areas along the deep scattering layer. I could mount it on my boat as a custom pocket mount, or maybe in a custom transom mount/pole mount setup.
I've done some reading and it seems like the 2 kHz 38BL- 9HR might be a good choice but I'm not certain about this.
These are my questions:
1) Does that transducer seem like a good choice for that specific use?
2) Does this transducer need to be surrounded on all sides by liquid to stay cool, or could this transducer be mounted as a pocket mount with just the face of the transducer exposed to the ocean? (Wet faced mount)
3) With the FCV295, when I have the MODE knob turned to HF, does that mean that the LF transducer is not transmitting at all? Meaning, could I leave it wired up and pull it out of the water without harming it, just so long as I leave the mode knob on HF?
4) Is there a place in the menu to instruct the machine to transmit at 1KW for my 200kHz transducer (SS264N) while also having the machine transmit at 2 KW for the 38-BL-9HR? Or does the machine know to transmit at the correct power somehow for each transducer, without being instructed?
5) When looking at the drawings of the 38BL-9HR, it appears that there are two holes in the transducer for bolts of some sort. Am I seeing that correctly?
Thanks.
Thanks.
