S
Gunnin,
You are correct the SS175HW is not in the FCV-295 transducer list. It uses an "A" Tap setting.
If you set the frequency for 200Khz I would set the Band Width control at 40Khz. This will allow you to slew the frequency down to 183Khz. Note that the FCV-295 is blocked out from working between 171-183Khz. If you want to try a lower frequency I would program it for 155Khz with the Band Width of 40Khz. This will allow to slew the frequency between 139 to 171Khz.
