Hello everyone
I have DRS6A-NXT and Navnet TZTL16, for LAN connection I use Switch HUB (D-link).
I use Switch Hub (D-link) because it connects to a PC (computer)
The problem appears Switch Hub off (non-active), when TZTL16 and Radar DRS6A are active.
After we re-enabled the Switch Hub, the DRS6A Radar was not detected in the TZTL16 "Data Source" menu. (no radar) and on PC it can't be detected
- 24 VDC Radar Power Check in good condition
- LAN cable Radar good condition
- we have tested the DRS6A-NXT Radar, we connected it directly without Switch Hub to TZTL16, still not detected in Data Source (No Radar)
With these cases, I hope any more suggestions, options, instruction
Thank you
Thank you
