If good now, it could be something that is loaded on the boat later. That install looks pretty good other than I would be a bit concerned about that VHF or AIS whip there. Distance is hard to tell in photos but NMEA 0400 requires at least three feet from VHF/AIS from radar. I wouldn't be running it in the housing area because you will pick up way too many close in reflections. Make sure you wait until you take it out on the water away from the built up marina to see how it really runs. If you have motor reels and other items back behind, it might be that when the boat is loaded you should test sector blanking the aft to see what happens. I like these wifi radars a lot but they are AUTO mode only so the settings and adjustments are limited. Sweet looking ride.
