DRS2D-NXT No Radar Message
AndrewHutton
Have an issue with my TZT3 and DRS2D-NXT. I occasionally get the No Radar message.
I can tell you it’s not a power issue or Ethernet. All connections are solid. I know this because if I turn it off, remove the radar inline fuse, wait thirty seconds, then replace fuse and reconnect it detects and sweeps with no issues. It stays on and working until it’s put in standby or unit is turned off. It may or may not repeat the problem. Sometimes it does, sometimes it doesn’t. Have walked away fine and comeback next week to the error message. Fuse never blows and there seems to be no pattern to it.
The boat sat unused for few months but had been fine. Could the radome be stuck? Odd issue. Can’t seem to figure it out.
It sounds like the radar should be evaluated for repair. If it stops talking like that and recycling fixes it, it sounds like an electronic component issue that should be easily be duplicated based on your finding. If in North America, I would recommend sending it in via RMA obtained from www.FurunoUSA.com - Support - RMA
