About 2 years ago I purchased a used DRS25A/NavNet 3D 12"MFD, PSU-13, HUB101 system and associated cables.
I set this system up in my garage to test it prior to installing it on the boat to verify it worked properly.
At that time, working with the support guys at Furuno, we determined that the power on sync signal was not functioning so the PSU/HUB/DRS25A did not turn on. I was told to install a jumper J7 on the PSU to force power on of those devices.
Once I installed the jumper, all units powered up and the system has worked flawlessly ever since it was installed on the boat.
About a month ago, I powered on the system and received the "No Radar Detected" message. I powered down and restarted the system a few times and then the radar was found again. This problem is now persistent. I have to power down and restart the system 8-10 times to get the radar to detect.
I have run a replacement ethernet cable from the Hub to the Radar and that does not solve the problem. Sometimes it works, sometimes it shows No Radar Detected.
The entire system (MFD, PSU, HUB and DRS25A) are powered on by a single 24V 30amp breaker (which I have even changed to be sure power was good).
I have discussed this issue with Furuno by telephone twice (two different techs) and receive completely different information each time, but neither tech was able to assist. One rep told me that having the jumper installed will NEVER work with the NavNet 3D. Clearly that isn't so as this has worked well for 2 years. Another tech suggested that this was a communication issue, which we already know, but didn't have any suggestions on how to troubleshoot other than to call a radar service company.
I have to say that I always loved the support guys at Furuno and have praised/recommended Furuno products to others based on fantastic support. But this time, I feel a bit let down, so thought I start a thread here to get some definitive assistance in how to narrow down what is happening, etc.
