PugSndBoater
Motor yacht with DFF1-UHD, B265LH transducer, and quad TzTouch2 displays. Curiously, the HF frequency seems to have lost… something (power? discrimination? gain?). Symptoms illustrated in photos attached to this posting:
1 - LF operating, about to toggle to HF frequency
2 - HF depth not registering
3 - back to LF restores function
Vessel has operated successfully and solidly on primarily HF frequency for the past 3-4 years in many depths of water, so I’m unsure what’s going wrong here. Vessel was stopped for a couple days at anchor and these symptoms appeared when the systems were powered on again. No shipyard haulout recently that might’ve fried the transducer from dry operation.
Tried stopping and restarting fishfinder Tx. Same result.
Tried power cycling everything. Same result.
Tried resetting the TzTouch2 fishfinder settings. Same result.
Tried doing the “Set Hardware to Factory Default” and reinitializing the finshfinder. Same result.
Tried power cycling everything again. Same result.
TzTouch2 displays are on software V7.01.
DFF1-UHD is on software V03.04, which was in fact upgraded not too long ago (early May on our system I believe), but this failure symptom started after we’d been operating on the new firmware for a while.
