25Cintender
Hello I know my system is a older Navnet 3d but I have a question. I am adding a MFD8 to my upper station and the network cable that came with my mfd 8 is to short to reach my network hub. I have a extra Furuno network cable that would make it long enough. Is there a connector I can use to connect the two male ends? Can I use a standard double female cable connector to connect the two cables? Or can you buy just the waterproof end that connects to the cable to the MFD8 I have have the tools to add RJ45 connectors and a long enough network cable. I need that waterproof connection to the back of the MFD8 since it will be weather exposed. Thank you.
