585, 50k
I have a 585 furuno, with a TM 260
On the 50k side, manual. Depths down below 300ft or more. My screen has a lot of interference. Like the whole screen, when the the gain is low like 2-4g. Fishing/Cruising Mode is fine. Just the Manual is out of whack.
On the 200k side is fine, doesn't have to much interference.
If i go shallower, it is fine on the 50k-200kside.
I also run a back up Raymarine gps/ff combo. So i was thinking, maybe it is interfering with the little p58, if it was. Than my whole 585 200k/50k would be all interfering as well.
The setup is new, bought it this year March 2012.
Any help would be appreciated
nofriends46@yahoo.com
Hiroshi808,
It's hard to say what is happening without seeing a screen shot of your sounder. But here are a couple of things you can try. First is to turn off your other sounder to see if that helps. Second is to do a master reset of the 585, this will restore the sounder to it default settings. If you still have problems please post a screen shot for us.
thanks snips
next time when i go on a next fishing trip, i'll post a picture.
In the mean time, how do i do a master reset?
With the machine "On" and working... Hit MENU...Down arrow under SYSTEM...until you get to RESET...Right arrow to highlight FACTORY RESET.... press ENTER... highlight YES and press ENTER.
