Wiring DFF1-UHD with PM275LHW (TZT 14)
Tolock1
After losing temp and not reading bottom greater than 800' on low or high I was told to replace the DFF1-UHD. I just installed the new box and have a few questions...
1. On the WAGO TB4 should I be attaching the bare wire in spot #2 with this transducer? Should the orange wire be connected in spot 3 or left off?
2. In the transducer setup it only shows a B275LHW in the menu, should I select this (is it the same as the PM275 LHW)? Should I be doing the setup through the TD-ID option?
3. Does it matter what temp port I select for the temp?
4. Should all the dipswitchs be off?
Thanks for your help.
Tom
Totock1,
The TX/RX capabilities doesn't change on the DFF1-UHD regardless of the transducer selected. Selecting the 275 "should' disable the ACCU-FISH and Bottom Classifation modes because of the 275 wide HF side. Personally I connect the white/brown temp wires to pins 4/5. Leave the dip switches in the default position.
