O
OrcaAye
I have questions on wiring a Furuno Navigation Suite that I acquired from a friend. Most important is to get the Autopilot to function and communicate with the plotter/ RDP
The System consists of:
1. 1824 Radar
2. RDP 148 Display
3. RDP 149 Display
4. Network Soundrr DFF-1
5. Nav- pilot 511
6. Heading Sensor PG- 500
7. Control for A/P FAP 5011
8. Handheld for A/P FAP 5021
9. Hub
Missing:
1. Rudder reference Unit
2. GPS Sensor
3. Some wiring
Questions:
A) I don’t know how the Nav- Pilot 511 should connect to the RDP’s. Through the hub? Or direct? At present there are 4 wires coming off of what the installation manual labels as NEMA In / OUT. The wires terminate in spade connections. Could these have gone to a terminal block to interconnect with a hub cable? The wires are not color coded so what goes where in the hub plug?
B) The PG 500 Heading Sensor has 5 wires out of the DP-10 port that terminate in spade connections, Could these have gone to terminal block to interconnect with a hub cable? These are color coded- willl they match up with the hub plug color coding?
C) I do not have a GPS sensor (antennae) for the system. Does this require a special GPS sensor, if so recommendations. And where would it plug into? Perhaps Data port 1 or 2 on the RDP 149 (these appear to have been used for something).
D) I do not have a Rudder Reference Unit. Recommendations?
Present Configuration (as best as I can tell):
Network Sounder DFF-1 connected to Hub.
1824 Radar connected to the RDP 148;
RDP 148 feeds Hub via Network Port;
RDP 149 feeds Hub via Network Port- but no connection to other instruments. Data Ports 1 and 2 appear to have been used at some time, but for what- GPS Sensor?
I understand most of the connections of the Navpilot: power, motor control, control heads, rudder reference, and Fluxgate PG 500. As stated in Question “A” there are four wires from NEMA IN/Out with spade terminals. Where do they go? There is no connection to Hub or RDPs
Heading Sensor PG 500 is connected to Nav pilot, but has 4 wires from AD -10 port with spade terminals. Where do they go?
Thanks for any help!
1. 1824 Radar
2. RDP 148 Display
3. RDP 149 Display
5. Nav- pilot 511
9. Hub
Missing:
2. GPS Sensor
3. Some wiring
Questions:
