Wifi problem
Status
Not open for further replies.
Aymen khelifi
Hi all,
I bought a TTZ10X in Europe to use it outside of Europe (in Tunisia). It was on version 25.11.2 which blocks the Wi-Fi connection. I updated it to version 25.21 but the Wi-Fi connection still doesn't work. Do you have a solution to suggest?
For questions outside of FURUNOUSA's service area please contact your local distributor.
The same with my unit. I am going to put 25.11.21.
Did you solve your problem? Furuno France told me to wait for new updates but they don't know when it will be available.
And do you use the unit normally?
How do you install the maps.. because i am about to return the item..
Which transducer do you use?
The choice of the transducer is a personal choice that depends on several parameters:
fishing technique
fishing area
Depth, nature of the bottom
Especially the fisherman's strategy: favoring prospecting over precision, or vice versa.
If you practice vertical technics, the B265LH is, in my opinion, the best choice.
Alternatively, the second option is to keep your P66 and pair it with a mid-frequency transducer such as the TM185M to take advantage of Furuno's BDS.
Status
