PugSndBoater
I’m working on a FLIR M400 install. The FLIR, given NMEA 0183 TTM input sentence, can camera-track targets. Vessel has 4 TZTL15F units (2 helm, 2 flybridge) and full Furuno (dual 711C, DRS6ANXT, DFF1-UHD, FA50, SC70).
1. What action taken on the Tztouch2 UI causes TTM sentences to be output?
2. Can multiple radar/AIS targets be output as TTM sentences and what action makes that happen? The FLIR unit will look at and dwell on multiple targets given separate TTM sentences about each.
3. [multiple TzTouch2s] How can I ensure TTM output to the FLIR regardless of which of the 4 onboard TZTL15F units the helmsman uses (e.g. on the flybridge or main helm)? That is, if I connect the FLIR to the NMEA 0183 output of TZTL15F #1 of the 4 onboard, is that the only display that can specify TTM targets or how can I ensure it’s possible to use any of the 4 TZTL15F units to do so? E.g. is TTM-target data already shared across the network where it doesn’t matter which TZTL15F is NMEA wired to the FLIR and target-selection on display #2 will output it via 0183 from display #1? Or perhaps can TZTL15F units output NMEA2K PGN 128520 so all 4 could then collectively drive the FLIR through an IF-NMEA2K2 gateway?
