PugSndBoater
Setup: 4x TxTouchXL units on the same network. Same Navpilot 711C we've used for several years previously with 4x TzTouch2 units. We're having two route/navigation issues that may or may not be related:
1. When I start navigating a route on one TzTouchXL display, it doesn't seem to start navigation on all of the display like I'd expect and like I think used to happen on our older TzTouch2 units. The navigation only starts on the single TzTocuhXL on which we actually started navigating. This behavior/issue happens even if the NAvPilot is off or not involved.
2. TzTochXL and Navpilot seem mostly unaware of each other for some reason. Specifically, if I start navigation via NavPilot using the controls of the TzTouchXL itself (e.g. by using the NavPilot item in the Route side menu), it does activate the Navpilot hardware correctly ("Navpilot activated" banner), but then I immediately get a "NavPilot deactivated" yellow banner on the TzTouchXL. The actual Navpilot itself remains activated (e.g. in Auto mode) but the TzTouchXL seems unaware of the NavPilot's state and is unable to control the NavPilot hardware. Also, if I start navigation via the Navpilot 700 display itself, the TzTouchXL is also unaware it's running. Both things lead me to believe there's some signal from the NavPilot back to the TzTouch units that is missing or failing, but I'm unsure what that may be, since I'm not sure what would be different from our previous TzTouch2 setup where this all worked.
Items I checked. Basically, the same setup we've had for years with the older 4x TzTouch2 displays, so I'm not sure what I'm missing.
- Sync sensors is enabled on the NavPilot, so it's using the same NMEA2K sensors as the TzTouch displays, but I get see these same problems even if I configure the NavPilot sensor selection manually
- TzTouchXls are outputting PGN 129283, 129284, and 129285, so appropriate nav data is on the canbus.
- Navpilot is outputting PGN 127237 (heading/track control) and 127245 (rudder) onto the NMEA2K canbus
- "Navigate with NAvpilot" is on in the Routes setting menu of all 4 TzTouchXLs
- The Navpilot-700 is visible on the TzTouchXL displays (Initial Setup -> Sensor List -> Can Bus Sensor), and the PGN sentences into the Navpilot is happening on its diagnostic display, so they do see each other on the canbus
