PugSndBoater
For a multi-display system (4x TzTouchXL units in our case), it would be great to have some kind of indicator (e.g. a small dot, asterisk, whatever) present or absent with each setting option in all of the menus to indicate whether the setting will sync across multiple displays on the same network or if the setting only applies to the current display. It's not obvious today which settings sync and which are local, making it difficult to know which things you have to set on each display if you want the setting to match across units, or which things are allowed to differ from display to display if you intentionally want differing behavior across units.
