Jimmy
I just finished install the TZTL12 + DFF-3D + B54 thru transducer,
The 3D and cross sounder was amazing,but have problem on SST ( sea surface Temp ) data in side data.
When first Power On in the SST data was 25.6 deg in 2 min ,after that the SST data keep show [ -16 deg ].and [ --- ] on SST data box.
I check all the wiring was fine.
The network and depth data were stable betwan TZT2 & DFF-3D.
The SST data souce select from : DFF-3D
The Equipment Software
*TZT2 : V8.01 ; *DFF-3D : V1.06
My question is : The DFF3D + B54 support SST DATA to TZT2 ?
If yes , have any way to check the temperature sensor was heath of B54 transducer?
VIDEO : TZT2_DFF3d_B54_SST issue
Thank you for your time to read, pls kindly advice.
Best,
Best,
