TZT3 + DFF3D bottom map not working
PolarMarine
This network also has a TZ Professional v4 latest build on the network. The computer has full PBG. The TZT3 16" does not show a DFF3D mapping layer. Tech support didn't have a ready answer. All other functions seem OK on the MFD and on the TZ Pro computer. They also share small platform layer information fine. All nav is good, and all other DFF3D functions seem to work great from both the MFD and computer. It is just the mapping portion on the MFD that does not work.
I'm out of ideas...
Well just starting with the basics, do you have it turned on?
- Maggy
- Maggy
I knew it had to be just that simple. Will check tomorrow at the dock and see how it goes. When I opened the data boxes in the past, I did not see that toggle.
Thanks Maggy!
It willwas the simple toggle on the right hand swipe menu. When selected, PBG started working fine. Looks like everything is good to go.
PolarMarine":2rhfezlf said:
Thanks Maggy!
Awesome! Fantastic! :jump :jump
Let us know what you think when you get the opportunity! :sail
- Maggy
