TZT2 sounder
rockfshr
I have aP66 connected to internal sounder and a SS264N connected to a DFF1. When I switch back and forth do I have to go into the transducer set up menu and change the transducers? Or is all I have to do is switch sources?
Thank you!
Rockshr,
When switching between the internal sounder and DFF1 you don't need to go into the transducer setup menu. However you should put one into the stand-by mode as it then won't create interference for the other.
Thank you Snips. Is there a better or quicker way to switch sounder inputs than going to Home ,Settings,Sounder ? Also how many sources can the TZT2 have?
Rockshr,
Sorry there aren't any short cuts to change sources.
The most sounder sources I have personally seen on a vessel is five.
