Helmsman,
You can connect the TZT12F's Ground Lug to the vessel's bonding system. There is a high possibility of electrical interference if you connect to the Vessel's Power Negative Buss Bar. If you connect to the the vessel bonding (Earth Ground), this will reduce the likelihood of any electrical interface to your marine electronics.
The best practice calls for installation of a Earth Ground bus bar that is dedicated for electronic component bonding, (typically installed near the helm or electronics area). That Earth Grounding bus bar is then connected to the remainder of the vessel’s grounding system, which again should be common with all of the vessel’s grounding and bonding systems.
- Deep Blue
