This seems to be an intermittent problem. its happened 3 times now recently & presently staying at fault.
The system is;
3 devices networked by Ethernet which appear to be communicating;
TZTL15F (me)
DRS4D-NXT
FA-50 ( i believe this unit has a separate roof mounted GPS ant)
Another 6 devices connected by CanBus FI-5002 junction box which are powered but do not appear to be talking???;
PG-700
GP-330B
FI-70
IF-NMEA2K2
NAVpilot-700
711C
The problem;
The FI-70 display and 711C auto pilot are powered up but not displaying lat/long, as they did before.
The FCV-295 is not displaying speed which is fed from the IF-NMEA2K2 converter, as it did before.
There are two roof mounted GPS antennas, the 330B is connected to the FI-5002 canbus & was selected as the GPS source in the TZT2. the other GPS i think may be directly connected to the FA-50 AIS. dont know its model, it doesn't appear in sensor list.
Its seems like the FI-5002 canbus network has stopped talking. The TZT is displaying lat long from its internal GPS (or maybe its getting it from the FA-50?) but we cant get lat long from the GP-330B on roof, as we did before.
When we selected the TZT to be the gps source it didn't share lat long with other devices on CanBus network.
All devices on the canbus network are connected to a FI5002 junction box. there isn't any backbone cabling so both terminating resistors in the FI5002 are on. I checked for power at JB supply terminals, 12v all good. I checked power on red black at the plugs of each device at JB all good 12V, each Blue White pair at JB has 3V.
Thinking about my previous statement of course all those terminals will have same voltages as the fi5002 parallels everything, doesn't it?
All the Can Bus devices are listed on the SENSOR list at "INSTANCE 0" and appeared to be greyed out. does that mean there not talking?
After i did a reset of the sensor list all the canbus sensors disappeared.
i believe this to be a loose wire type issue as it happened when we were stuffing about trying to fix a wiring issue with the FCV-295. thats now fixed. I think we disturbed something.
So my i guess my question is what the best way to fault find the canbus cabling?
Or is there a way to select different devices in the TZT2 to help indicate where the wiring issue is?
Any advice appreciated.
Mark
