C
Cruble
Running a total of 4 TZT units with a master and slave in the pilot house. The two slave FB units are often not turned on but function well when used.
Pilot house units are connected to 23" Dell touch screens and Gyration wireless mouse.
The problem unit is the slave. At the dock it will display S-57 or Raster data with no issues. Zoom in and all the detail is there.
When underway the unit chirps and a 'scanning drives' window appears at the top of the screen. The chart detail is lost, what is left behind is the vessel, track and the Overzoom grey screen 'message'. Same occurs when the Raster chart is set to primary chart. Periodically the chart data will return and disappear cyclically.
No data is being overlayed onto this chart nor is it a shared/split screen.
This event can sometimes be mitigated by activating the auto pilot. The chart data will return until the autopilot is set to stby where it is lost immediately.
The green bar at startup displays 1950123-05.01 (software version?)
The system software is up to date however it doesn't display what software version it is running. I have a verified connection to a wireless LAN.
I've turned off much of the chart display features as well as nearly all the weather data in a effort to reduce the processor load.
We've got a substantial number of charts loaded, enough to do the entire loop and then some. Master has the SD card, 59 gb capacity with 50.7 used.
Chuck
Chuck
