tz touch 2 fishfinder
jimalmond
during the install of the new tz 2 from the nn3d in setting up the transducer hooked directly to the tz 2 there is no transducer listed for what i have which is the b164 with 20 degree tilt
only selection is 50/200 t1..is this the correct unit to select for this ducer if hooked to tz 2
jim
You would pick MANUAL not transducer MODEL.
Then put in the frequency and power (600 or 1kw). In your case you will pick 50 for the Low Freq, 200 for the high, and 1KW power for the B164.
johnny,
i did this sunday after reading through the install manual but was not in water so will have to check to see if it works any better than it did with this selection
jim
