bfeehan911
I recently installed and connected an Airmar B125 to my touch 2. It shows all of the features, except my sea surface temp is way off. It currently reads 5 degrees Fahrenheit. I know there is a setting to calibrate the offset but it is still not enough offset to get the actual SST. Any suggestions on how to correct this? As a side note I had the same problem on my old transducer. It seems that when I updated the Furuno software last year it started to throw it off. I actually thought that I had a bad temp sensor on my old transducer, hence purchasing the new one.
