If the sounder light is solid, it is like sparky says; it is a network error. While you might have a transducer problem as well, that isn't what the current problem is. The sounder indicates it isn't seeing the MFD on the network (regardless of software source settings). Most would try another hub or cable but you could always have the units into your dealer for testing.
