Transducer for 1100L
Removing 585 with 1k tru hull and replacing with 1100L
What would be the best transducer for fishing in Hawaii for yellow fin and other paligic fish
S
Keikikai1,
What kind of vessel/size do you have and do you have any pictures of how the transducer is currently mounted?
It's a fiberglass 25 foot radon used for commercial
S
Keikikai1,
See post Speed Sensor Location, Brucefish1 just asked the same question about posting pictures.
S
Keikikai1,
Thanks for the pictures, I have a couple of questions for you. I see that the hull closer to the bow comes down to a VEE and further aft the hull tapers up and flattens out. Do you know the vertical distance between the deepest part of the VEE and the flat spot where the current transducer is mounted? What is the vertical clearance between the flat spot where the transducer is now and the cross beams on the trailer? Looking that how the transducer is currently mounted does it work well when you are at speed? Is there a flush transducer mounted aft of bronze one, if so what is that connected to?
