Spurious ARPA Targets DRS25A-NXT
Receive side can be damaged by RF. It is like having someone scream in your ear and then saying that you still have your ears ringing when they quit screaming. Disregard as you wish but you can't change physics and when guidelines are broken sometimes there is a price to be paid.
Understandable when the starlink was active, but when it's completely powered down?? Quitsa has the problem with no Starlink.
DISREGARD - Didn't have the ARPA overlay turned on -- Very strange this morning, going past my 3rd set of hard targets (one sea buoy and 2 groups of fishing boats), none have auto acquired (all were inside of 2nm). I did have some clutter out of eyesight that were Acquired - could have been real.
If worried about software the radar, it can be downgraded a version or two to test that theory. Not every boat is the same. Because there is a similar issue doesn't mean the answer is the same for each case. If it is something with the new software the parent company will sort it. If it is something on the boat, then that must be addressed on its own merits. I will say when it comes to RF the longer an issue happens the more damage that can occur. I see GPS antennas in the radar beam have the receive side damaged to the point they don't pick up at all. They end up replacing them every three years until someone finally moves it out of the beam. Placement is a valid possibility for anyone pressing the envelope.
On the boat now, never turned on starlink, the unit is a brand new remaned pumpkin. The false targets build and build. First pic is without target analyzer. Second pic is with.20251226_111834.jpg20251226_111809.jpg
3 different boats, different installations but same radar and MFD model - only other thing common is the behavior of the radar and phantom targets.
Not a statistically significant sample size admittedly.
Today, when I turned on the ARPA overlay I've probably only had 3 phantoms in the last 90 minutes and they all went away on their own.
Yes. I have never been able to correlate it except for offshore on a very calm day with nothing nearby. Then the only spurious targets are from the wake. But that doesn’t happen consistently and sometimes I get the extra targets under the same conditions.
I had the issue long before I got the Starlink. In any case, mine is at least 8 feet away below and out of the beam.
A possible consideration might be to have an option to keep Arpa active with out auto tageting, you would manually select targets to aquire.
I would certainly hate to give up ARPA. It is one of the features that puts Furuno radars way ahead of the other manufacturers and an important safety feature.
100% Agree.
I think you may be on to something. I had a great cruise this week with flat, calm seas just south of Miami heading into Hawks Channel. Radar/ARPA was working perfectly with a bunch of traffic nearby. As I got further down into the Keys, the sea state picked up a bit and so did the phantom targets. Mine often starts with the wake as well but also when I've seen sea condition returns on the display.
Same here. I realize that the one thing I did not try was setting the sea state filter manually. My boat is hauled out now Maybe Bayhouse can experiment with setting sea state higher than auto and see whether that helps.
I am wondering the extent to which others have experienced the problem. It seems to be confined to people who have the DRS25A-NXT with a six foot array.
I have the DRS 25 with four foot boom.
Can't say that I recall playing with that setting and will give it a try when I'm next out on the boat. My long trip is over so will have to wait for fishing.
My primary suspect is the “ARPA Advanced Settings” we are sternly warned not to change. I think we won’t get a solution until the Furuno engineers replicate the issue and change the algorithms. But still worth seeing what happens if the sea state filter is cranked up higher.
I'm out fishing (sadly not catching) and had some time to play with Manual Sea State in some fairly sporty seas. At the following settings (no other boats close):
0 - explosion of targets right away
50 - rapid target identification
75 - much slower and fewer targets
80 - so far, no spurious targets for a good hour plus
