Finally finished installation on a new DFF1-UHD to complement existing DFF3. To highlight that installation of the new sounder module uses 2 transducers as discussed with Snips, a B265LH and a B175W via selector switch. The B265 was connected up to last week to a Raymarine chirp module. DFF3 uses an R309 transducer. Both the Raymarine and DFF3 were working fine for the past year. The MFD used are 2 TZT14 and 2 computers running the new Nobeltec TZ Professional.
I find now I have 3 problems. The DFF1 appears to be working fine with both transducers but notice that the low frequency appears to be significantly weaker that when operating with the RM module. I will continue fine tuning unit to see if I can make it work better. The system worked fine on both TZT's but refused to work on the Nobeltec saying no connection.The menu option for the sounder has the transmit option unmarked and if I select it it works for a few seconds and unmarks itself again. Before the installation of the DFF1-UHD it worked fine in all units.
The DFF3 though is now a major issue. Both sounders worked for about 6 hours fine, except for the notes above, Now the DFF3 will not transmit at all and presents an empty screen. When I check to see if there are issues in the configuration I find that the transducer configuration for the low frequency changes by itself. There is no way to make the unit work. Cay you help? I have screen shots of the configuration that I can send so you can see them.
Thank you.
Thank you.
