I recently upgraded to TZT2-12. Works great but not happy with sounder. The only component I kept was the transducer. (Airmar B164-20, p/n 41-395-1-01, Date 02/10). I will try to attach the settings as I may have made a mistake. From your web site this is one of the transducers you recommended. I can’t find it in the models portion of the set up. I’m not able to get Rezboost. My boat is a 26’ Regulator. It does not have a pocket for a B260. I would like to make the existing transducer work but I can install a new one if that’s my best option. I have been researching this for awhile . I would prefer a transom mount : What’s your recommendation?
Thank you
Another question. On The Furuno wed site under accessories, transducers for TZT2.I see two part numbers,556-TID-LTD/20 (B-164) which is the same transducer I have and another transducer part number 525TID-TMD (TM258) which I thought may work for my application. At the top of this list there is a note as follows
This unit utilizes a 10-pin Transducer/Multisensor connection. These transducers enable all standard Fish Finder features including RezBoost, but DO NOT support Bottom Discrimination. To utilize the Bottom Discrimination mode of the TZTL12F please select a transducer from the "Bottom Discrimination Transducers" list.
This would indicate to me that all of the transducers on that list will provide all the functions except Bottom Discrimation on the TZT2.
Neither one of the transducers listed above are on the list in the setup menu as models so they must be manually entered.
On page 7-15 of the owners manual I believe it states that REZBOOST Is not available if,
“Not available if the transducer is manually selected or a non compliant transducer is used”
Am I understanding this correctly?
Thank you
Wayne
Thank you
Thank you
Wayne
