Hi everyone,
I’m looking for some guidance on properly configuring my transducer settings. I recently purchased a boat and am still dialing in the electronics. The boat is equipped with the following:
Electronics onboard:
Model Number
From what I can tell:
38kHz:38BL-15HR
However, since the R109LHW is a wide-beam CHIRP transducer, I’m unsure if this is truly the best selection or simply the closest legacy profile.
Thanks in advance.
- TZTL15F MFD
- Furuno Network Sounder DFF3 (28 kHz – 200 kHz)
- Furuno Multi-Beam Sonar DFF-3D (165 kHz)
- Airmar R109LHW (Low CHIRP 38–75 kHz / High CHIRP 150–250 kHz)
- 165T-B54 (165 kHz, used with the DFF-3D)
Current configuration on the TZTL15F
Under Transducer Setup Type = Model, the settings are currently:Model Number
- 200kHz:50/200-1ST
- 200kHz:50/200-1ST
- 50kHz:50/200-1T
- High Frequency Min: 196 kHz
- High Frequency Max: 205 kHz
- Low Frequency Min: 48 kHz
- Low Frequency Max: 51 kHz
My concern
I don’t believe these settings are correct for the Airmar R109LHW, but I could be mistaken.From what I can tell:
- These appear to be fixed 50/200 kHz transducer profiles
- I do not see a specific R109LHW entry
- I also do not see a clear 38–75 kHz wide-beam CHIRP option
38kHz:38BL-15HR
Questions
- Is 38kHz:38BL-15HR the correct (or best available) low-frequency selection for an R109LHW on a DFF3?
- Is there a more advanced or recommended configuration for wide-band CHIRP transducers when an exact model is not listed?
- Should the high-frequency side be configured differently to better reflect the 150–250 kHz band?
- Are there any best-practice settings (gain, pulse length, frequency limits, etc.) that help optimize performance with this combination of DFF3 + R109LHW?
Thanks in advance.
