Most Simrad RRUs will not work because they are frequency based reference units. Furuno like many others works off of a resistive based RRU. You can check but the Simrad most likely will not work. If it is resistive based it should but most are not. The pilots are pretty easy to install and we have knowledgeable techs in support if you have any questions along the way.
