Hi, will the transom mount side scan transducer work well on a deep v 24 degree deadrise boat? planning on placing it down low at the center of keel , where the drain is? inboard outboard propulsion.
@Deep Blue will likely ask you for photos of the hull from different angles. The easy answer is yes, as long as you can get clean water without turbulence, it would work.
Just like Sparky Wire suggested, If you want to provide any pictures of the vessel's hull, I can make a suggestion for the best side scan transducer mounting location.
