Screenshot interpretation fcv587 - P66
spooled1
Hi Furuno techs,
Attached is the following screenshot that I'd like some help interpreting.
Here's what I can tell you:
Scroll speed 1/2
1) The upward track left of screen was a 77cm snapper
2)The upward peak right of screen and track above the peak was a 79cm snapper
3) A battle was had with fish #2 between 50 and 75m
Now see the 5 dots above the zero on the 80m marker, would you consider them 5 individual fish or more like a doubling as the screen advanced while the fish moved?
Does the upward track extending from the 80 suggest 2 or maybe even 3 fish heading back down to the seafloor or did fish#2 simply have an opposing cone angle approach to fish#1?
Any tips to get even better results from a P66
Cheers,
Spooled1,
It is very hard to second guess what you were seeing. If you hadn't given any details I would have said due to it's path that the first diagonal line (colored white) was a jig and that three fish came up at the red X to take a closer look at it. Your screen shot is very similar to one taken while fishing Black Sea Bass.
Thanks Snips,
Yeah backstory is important.
Attached is a zoom of the same image. Because they're 5m depth increments you can see the snapper blobs are each about 80cm in size.
Question: Looking at this, how many fish are represented by the yellow blobs above the zero. I'm counting 5 blobs but how many would you call fish and how many are showing signs of being a repeat of the same fish?
Spooled1,
To be honest it's hard to tell for two reasons. Using the screen advance you are seeing half the information you would see using 1/1. Also looking at the tail of the bottom it appears that you were rolling around quite a bit.
